Introducción
If the vibrating function on your Samsung Galaxy Tab 4 7.0 Sprint is not working properly, it might be necessary to replace the vibrating mechanism. Use this guide to replace the vibrator.
Qué necesitas
Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
Insert the pointed tip of the nylon spudger between the vibrator and the board.
Carefully push the vibrator out and away from the board.
