Saltar al contenido principal
Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: paso 1, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 2, imagen 3 de 3
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 3, imagen 3 de 3
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 6, imagen 3 de 3
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 7, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 7, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 7, imagen 3 de 3
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 8, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 8, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 8, imagen 3 de 3
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: paso 9, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: paso 9, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: paso 9, imagen 3 de 3
    • Flip the motherboard over to view the back side.
    • Locate the rear-facing camera on the motherboard.
  10. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 10, imagen 2 de 2
    • Use a plastic opening tool to unlock the rear-facing camera wire from the motherboard by flipping up the retaining flap.
  11. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 11, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: paso 11, imagen 2 de 2
    • Use your fingers to grip the camera and carefully pull it out and away from the motherboard
Conclusión
Equipo
Cal Poly, Team 18-3, Forte Fall 2016 Miembro de Cal Poly, Team 18-3, Forte Fall 2016
CPSU-FORTE-F16S18G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 717
