Saltar al contenido principal
Samsung Galaxy Tab 4 7.0 Speaker Replacement
Qué necesitas
  1. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: paso 1, imagen 2 de 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Speaker Replacement: paso 2, imagen 1 de 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • In order the speaker connection, you must first peel back part of the surrounding water gasket.
    • With the tweezers, grab the overhanging corner and peel the gasket back slowly.
    • If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
  4. Samsung Galaxy Tab 4 7.0 Speaker Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement: paso 4, imagen 2 de 2
    • Now you should be able to lift the speaker out of it's small fitting with the tweezers.
Conclusión
2 personas más completaron esta guía.
Aubrey Goodwin
Miembro Desde 08/31/15
2,700 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-3, Remmell Fall 2015 Miembro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Miembros
12 Guías creadas
2 comentarios
Where can I order the new speaker?
Dorrie Stotko - Contestar
This would be better if it were a YouTube video so we could actually see it being done.
robinmyrobin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 3,952
