Saltar al contenido principal
Samsung Galaxy Tab 4 7.0 Screen Replacement
Qué necesitas
  1. Samsung Galaxy Tab 4 7.0 Screen Replacement, Back Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Screen Replacement, Back Panel: paso 1, imagen 2 de 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 2, imagen 1 de 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: paso 3, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: paso 3, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 4, imagen 3 de 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 5, imagen 2 de 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 6, imagen 2 de 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
  7. Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: paso 7, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: paso 7, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: paso 7, imagen 3 de 3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
  8. Samsung Galaxy Tab 4 7.0 Screen Replacement, Screen: paso 8, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Screen Replacement, Screen: paso 8, imagen 2 de 2
    • Evenly heat the surface of the screen using your heating tool to loosen the adhesive that is holding the screen to the phone case.
    • If using the heating pad, you may have to reheat it once or twice during this process.
    • If you're using a heat gun, avoid heating one spot for more than a few seconds.
  9. Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 9, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 9, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 9, imagen 3 de 3
    • Carefully insert the spudger between the glass and the chrome outer frame of the tablet.
    • Now, slowly pry your way around the screen to loosen the glass from the frame.
  10. Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 10, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 10, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Screen Replacement: paso 10, imagen 3 de 3
    • After you’ve removed the glass from the screen, feed the chip connection through the phone casing.
    • The screen may need a little more force to separate from the upper edge of the tablet.
Conclusión
36 personas más completaron esta guía.
Aubrey Goodwin
Miembro Desde 08/31/15
2,700 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-3, Remmell Fall 2015 Miembro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Miembros
12 Guías creadas
11 comentarios
Where is the microfuse located?
bbruns - Contestar
Do you have to remove the battery to replace the screen?
Vic Rector - Contestar
This is digitizer replacement guide - not screen replacement !!
K P - Contestar
This worked perfectly for me. Thank you!
gjarmour - Contestar
This worked perfectly for me. I just bought the assembly instead of going through the full deal (which if I had it would have saved me about 30 bucks overall). But was easy enough to do anyway. I still intend to get the digitizer/glass and finish so I have a spare for future breaks. (I have kids and they are hard on these tablets)
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 48
Todo El Tiempo: 46,279
