Saltar al contenido principal
Samsung Galaxy Tab 4 7.0 Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: paso 1, imagen 2 de 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 2, imagen 1 de 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: paso 3, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: paso 3, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: paso 3, imagen 3 de 3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 4, imagen 3 de 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 5, imagen 2 de 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: paso 6, imagen 2 de 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: paso 7, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: paso 7, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: paso 7, imagen 3 de 3
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
Conclusión
9 personas más completaron esta guía.
Aubrey Goodwin
Miembro Desde 08/31/15
2,668 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-3, Remmell Fall 2015 Miembro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Miembros
12 Guías creadas
3 comentarios
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Contestar
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Contestar
टॅब पार्ट खरेदी करना है मुझको
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 4,149
