Introducción
Replacement guide for the micro USB charging port on a Samsung Galaxy Tab 4 10.1 android tablet.
The battery only needs to be disconnected—skip steps 3, 5, and 6.
Herramientas
Partes
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Remove the two 2.7mm Phillips #00 screws from the micro USB port.
Remove the micro USB retaining bracket.
7 personas más completaron esta guía.
2 comentarios
Thank you so much for simplifying this guide for us novices. I have tried watching two videos where they assume I already have some Samsung repair knowledge. I feel confident I will be able to get the tablet up and charging in no time.
There is no need to remove the battery, only detach the power connector, cheers!
