Saltar al contenido principal
Samsung Galaxy Tab 4 10.1 Digitizer Replacement
Qué necesitas
  1. Samsung Galaxy Tab 4 10.1 Digitizer Replacement, Battery: paso 1, imagen 1 de 2 Samsung Galaxy Tab 4 10.1 Digitizer Replacement, Battery: paso 1, imagen 2 de 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 2, imagen 1 de 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 4, imagen 1 de 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 5, imagen 1 de 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 6, imagen 1 de 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Digitizer Replacement, Digitizer: paso 7, imagen 1 de 1
    • Use the flat end of a spudger to disconnect the home button.
  8. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 8, imagen 1 de 1
    • Use an iOpener to weaken the adhesive around the display.
  9. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 9, imagen 1 de 1
    • Wedge an opening pick between the digitizer and display frame.
    • Slide the opening pick around the perimeter to separate the two pieces.
  10. Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Tab 4 10.1 Digitizer Replacement: paso 10, imagen 2 de 2
    • Lift and remove the digitizer.
Conclusión
7 personas más completaron esta guía.
Blake Klein
Miembro Desde 01/29/17
70,583 Reputación
50 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 21
Todo El Tiempo: 3,768
