Saltar al contenido principal
Samsung Galaxy Tab 3 Lite Speaker Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 Lite Speaker Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Rear Case: paso 1, imagen 3 de 3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Speaker Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement: paso 2, imagen 3 de 3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite Speaker Replacement, Speaker: paso 3, imagen 1 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Speaker: paso 3, imagen 2 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement, Speaker: paso 3, imagen 3 de 3
    • Use one of the plastic opening tools and place it somewhat firmly on one of the two openings in the plastic around the speaker.
    • Apply pressure and pry the speaker out of its seat. The speaker should just pop out.
  4. Samsung Galaxy Tab 3 Lite Speaker Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 3 Lite Speaker Replacement: paso 4, imagen 3 de 3
    • Using a spudger, carefully pry up the speaker ribbon cable.
Conclusión
8 personas más completaron esta guía.
Equipo
USF Tampa, Team 11-1, Cheng Spring 2016 Miembro de USF Tampa, Team 11-1, Cheng Spring 2016
USFT-CHENG-S16S11G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,201
