Saltar al contenido principal
Samsung Galaxy Tab 3 Lite Rear Case Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 Lite Rear Case Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy Tab 3 Lite Rear Case Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy Tab 3 Lite Rear Case Replacement, Rear Case: paso 1, imagen 3 de 3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Rear Case Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab 3 Lite Rear Case Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab 3 Lite Rear Case Replacement: paso 2, imagen 3 de 3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
Conclusión
To reassemble your device, snap the screen into the case.
12 personas más completaron esta guía.
Kevin Hicks
Miembro Desde 02/09/16
1,587 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 11-1, Cheng Spring 2016 Miembro de USF Tampa, Team 11-1, Cheng Spring 2016
USFT-CHENG-S16S11G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 22
Todo El Tiempo: 3,932
