Saltar al contenido principal
Samsung Galaxy Tab 3 8.0 Audio Jack Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Battery - Open up the tablet: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Battery - Open up the tablet: paso 1, imagen 2 de 2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Back Cover: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Back Cover: paso 2, imagen 2 de 2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Battery: paso 3, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Battery: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Battery: paso 4, imagen 1 de 1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Audio Jack: paso 5, imagen 1 de 1
    • Disconnect Audio Jack from Motherboard.
  6. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: paso 6, imagen 1 de 3 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: paso 6, imagen 2 de 3 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: paso 6, imagen 3 de 3
    • Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 4-2, Brown Fall 2014 Miembro de USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 1,868
