Saltar al contenido principal
Samsung Galaxy Tab 3 10.1 Battery Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: paso 1, imagen 2 de 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 2, imagen 2 de 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: paso 3, imagen 1 de 3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: paso 3, imagen 2 de 3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 4, imagen 2 de 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 5, imagen 3 de 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 7, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 7, imagen 2 de 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: paso 8, imagen 2 de 2
    • Lift with a nylon spudger to remove the battery.
Conclusión
75 personas más completaron esta guía.
Corey Brown
Miembro Desde 06/24/16
8,682 Reputación
11 Guías creadas
7 comentarios
Great, Thanks for the help. It was very useful.
nyhorseracing - Contestar
why are there white lines all over the screen after a new battery was installed
Rosita Fowler - Contestar
brilliant ! worked extremely well !
Carmelo Aquilina - Contestar
Thank you very much for the information. I have one question, though. The new battery works, but it takes a VERY long time to charge. More than a day, in fact. Any idea what could be causing that? Is it possible that one of the connections is not tight enough? If so, which connection might that be?
Thank you.
Paul Ross - Contestar
Very easy instructions. Thank you. My only snag was that the ten screws holding the battery were extremely reluctant to undo. wrecked the IFxit screw driver. Fortunately, I had another one. My tip for anyone doing this little job, is to use quit a lot of downward pressure on the screws. Turn them 1/4 turn anticlockwise and back again. Do this several times until they turn freely. You will then have an easy job. I will replace those screws with a tiny blob of 'Never Seize'.
Keith Aldworth - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 44
Ultimos 30 días: 272
Todo El Tiempo: 42,959
