Introducción
Use this guide to replace the battery in your Samsung Galaxy Tab 3 10.1.
Qué necesitas
Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
45 personas más completaron esta guía.
4 comentarios
is there a diference between the lte, 3g and wifi versions of the samsung tablet
thanks for the information. i will use it wisely.
Battery changed, works fine !
Thank you for the tuto :-)
Great guide thank you.
My cover is not flush, even though I carefully attached the top first then downwards - I'm just clumsy I guess.
