Introducción
How to replace the touch screen digitizer. Do not attempt unless touch screen is beyond repair as it will crack upon removal.
Qué necesitas
Power the device down completely
Remove the SD card from the SD card slot.
Using the Phillips #00 precisions screwdriver, remove the 12 4mm screws holding in the motherboard.
Release all flex cables on the upper portion of the motherboard.
Using the plastic pry tool release the sensor flex cable from its socket.
With the same tool release the camera flex cable from its socket.
Release the front camera flex cable from its socket.
Release the side button's flex cable from its socket.
4 personas más completaron esta guía.
