Saltar al contenido principal
Samsung Galaxy Tab 2 7.0 Speaker Replacement
Qué necesitas
  1. Samsung Galaxy Tab 2 7.0 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Speaker Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 2 7.0 Speaker Replacement: paso 2, imagen 2 de 2
    • Using a phillips head screwdriver, remove the two 4mm screws holding down each speaker.
  3. Samsung Galaxy Tab 2 7.0 Speaker Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab 2 7.0 Speaker Replacement: paso 3, imagen 3 de 3
    • Locate the flex cable attaching each speaker to the motherboard.
    • Carefully use a nylon spudger to lift the cable and detach it from the motherboard.
    • Lift the speaker out of the device.
    • If the speaker does not come out easily, use a flat tool under the flex cable to slightly lift the speaker out of place before removing it with your hands.
    • Be careful when working with flex cables. Excessive force and sharp tools have the potential to damage these components.
Conclusión
Katija Tarailo
Miembro Desde 03/02/17
460 Reputación
3 Guías creadas
Equipo
IUPUI, Team S3-G1, Harley Spring 2017 Miembro de IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 752
