Saltar al contenido principal
Introducción
Cameras can be damaged by water or by physical impact, but it is much easier to replace than you may think. Follow these few simple steps so that you can get back to capturing the world around you on your tablet.
  1. Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Using a phillips head screwdriver, remove the 6  4mm screws holding the motherboard in the device.
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Locate the 8 flex cables attached to the motherboard. Using a nylon spudger, gently detach each flex cable from the motherboard. Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Locate the camera towards the top of the device.
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
Conclusión
2 personas más completaron esta guía.
Katija Tarailo
Miembro Desde 02/03/17
418 Reputación
3 Guías creadas
Equipo
IUPUI, Team S3-G1, Harley Spring 2017 Miembro de IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 473
