Saltar al contenido principal
Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement
Qué necesitas
  1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement, Auxiliary Port: paso 1, imagen 1 de 1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert.
  2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 2, imagen 1 de 1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding holding the battery on the device.
  3. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 3, imagen 3 de 3
    • Gently detach the set of wires clips connecting the battery to the device using a nylon spudger.
    • Remove the battery and set it aside.
  4. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 4, imagen 1 de 1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  5. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 5, imagen 3 de 3
    • Locate the flex cables attached to the motherboard. Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp tools have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  6. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 6, imagen 3 de 3
    • Locate the yellow brackets at the bottom of the device.
    • Using a phillips head screwdriver, remove the single 4mm screw on each bracket, located on either side of the auxiliary port.
    • Lift the brackets from the device and set them aside.
    • You may need to use a nylon spudger, or any flat tool, to lift the brackets out of their place.
  7. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 7, imagen 1 de 1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small metal covering off of the auxiliary port.
    • This will reveal a rubber covering.
  8. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 8, imagen 1 de 1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small rubber covering to expose the auxiliary port.
    • This will reveal the auxiliary port.
  9. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: paso 9, imagen 1 de 1
    • Lift the auxiliary port with a nylon spudger.
    • Remove the auxiliary component.
    • It is easiest to lift this piece from the innermost side of the port, opposite of the opening.
Conclusión
5 personas más completaron esta guía.
Katija Tarailo
Miembro Desde 03/02/17
460 Reputación
3 Guías creadas
Equipo
IUPUI, Team S3-G1, Harley Spring 2017 Miembro de IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 2,067
