Saltar al contenido principal
Samsung Galaxy Tab 2 10.1 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 2, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 2, imagen 2 de 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery Disconnect: paso 3, imagen 1 de 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 4, imagen 3 de 3
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Front Camera: paso 5, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Front Camera: paso 5, imagen 2 de 2
    • Gently lift the camera from its socket with the flat end of the heavy-duty spudger.
  6. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently lift the gold cable connector with the flat end of the heavy-duty spudger to disconnect it from the device.
  7. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Charger Port: paso 7, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Charger Port: paso 7, imagen 2 de 2
    • The charging port cable is the black cable connected to the charger port. Using your fingers, peel the green tape off of the charging port cable connector.
  8. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 8, imagen 2 de 2
    • Using the flat end of heavy-duty spudger, carefully lift the black tab that holds the charger port cable in place.
    • Slide the cable out.
    • There is a small strip of adhesive holding the charger port cable to the battery. You may need to slide the heavy-duty spudger between the cable and the battery to slide the cable out.
  9. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 9, imagen 1 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 9, imagen 2 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 9, imagen 3 de 3
    • Use the Phillips 000 screwdriver to unscrew the two 3mm screws holding the charger port in place.
  10. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 10, imagen 1 de 1
    • Use the flat end of the heavy-duty spudger to lift the white microphone piece until it is removed from its socket.
  11. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 11, imagen 1 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 11, imagen 2 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 11, imagen 3 de 3
    • Be sure to insert the spudger underneath the charger port and not inside the charger port to avoid damaging the component
    • Slide the flat end of the heavy-duty spudger under the charger port.
    • Make sure the spudger is all the way to the back of the cavity and slide horizontally across the bottom to break the adhesive.
  12. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 12, imagen 1 de 1
    • Lift the charger port with the flat end of the heavy-duty spudger and remove it from the device.
  13. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery: paso 13, imagen 1 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery: paso 13, imagen 2 de 3 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Battery: paso 13, imagen 3 de 3
    • Using your fingers, remove the green tape holding the three ribbon cables down.
    • Using the flat end of the heavy-duty spudger, carefully lift the black tab that holds the leftmost, black ribbon cable in place. Repeat this step for the gold ribbon cable and the black ribbon cable.
    • Using your fingers, gently slide each of the three cables straight out of the connectors.
  14. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 14, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the ten 3mm screws that hold the battery down.
  15. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 15, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 15, imagen 2 de 2
    • Lift the battery with your hands and remove it from the device.
  16. Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Motherboard: paso 16, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement, Motherboard: paso 16, imagen 2 de 2
    • Using the flat end of the heavy-duty spudger, lift up the black ribbon lock directly left of the headphone jack from the black side.
    • After lifting up the lock, insert the heavy-duty spudger underneath the gold ribbon and slide to disconnect the gold ribbon.
  17. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 17, imagen 1 de 1
    • The rear camera may pop out.
    • Using the flat end of the heavy-duty spudger, gently lift up the ribbon lock directly above the one in the previous step from the brown side.
    • After lifting up the lock, remove the gold ribbon with the heavy-duty spudger as you did in the previous step.
  18. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 18, imagen 1 de 1
    • Use the flat end of the heavy-duty spudger to pop off and disconnect all the marked connectors attached to the motherboard.
  19. Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 19, imagen 1 de 2 Samsung Galaxy Tab 2 10.1 Motherboard Replacement: paso 19, imagen 2 de 2
    • After disconnecting all of the connectors, push up on the motherboard with your thumbs to dislodge it from the tabs fastening the bottom of the motherboard. Then lift up the motherboard to carefully remove it from the device.
    • You may need to repeat this step a few times. The motherboard can be difficult to remove.
Conclusión
19 personas más completaron esta guía.
Equipo
Cal Poly, Team 6-26, Amido Winter 2015 Miembro de Cal Poly, Team 6-26, Amido Winter 2015
CPSU-AMIDO-W15S6G26
5 Miembros
14 Guías creadas
5 comentarios
Is there any sodering required to install it?
Ross Hanson - Contestar
All connections with other components come via cable connectors at different points on the board, but all components of the motherboard come complete already on the board, many with EMI shields.
Here is the link to the part product page which can give you pictures of the part itself which looks like the final picture of Step 19
Robert Myers - Contestar
The Instructions and illustrations were very helpful to follow and replace Motherboard for Samsung galaxy tablet S2 10.1,
I will need to purchase the part at our local elecrtonics shop and hopefully might find one and do the replacement following your instruction guide.
If not able to find at our local shops then I would place order with you and purchase part from you.
Thank you very much for kind assistance,
Regards,
Charlie Jay Klobill,
Wabag, Enga Province, PNG - 29/03/2020
Charlie Jay Klobill - Contestar
If I purchase a new motherboard and replace mine,will I have to load another operating system into it? If I do,is this an easy thing to do and where do I get it from? Thanks Steve Canode
scanode - Contestar
i need a motherboad
shivam Kumar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 87
Todo El Tiempo: 16,692
