Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will teach you how to remove the back cover from your tablet, a prerequisite step to the other guides.
Partes
No se especificaron partes.
  1. The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead. Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Gently lift the screen up with your finger. If the screen will not separate from the back cover, try repeating step 1.
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
Conclusión
Equipo
Cal Poly, Team 6-26, Amido Winter 2015 Miembro de Cal Poly, Team 6-26, Amido Winter 2015
CPSU-AMIDO-W15S6G26
5 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 192
