Introducción
In this guide, you will learn how to remove the back panel for either replacement or to get to other components in your Samsung Galaxy Tab 10.1.
Partes
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
13 personas más completaron esta guía.
3 comentarios
Very interesting, but my note 10.1 does not have these two screws adjacent to the charge point as you describe. So mine is a bit different. There are no screws anywhere on the tablet. So how do I take the back off mine ??
It currently won’t start and I have read about a fix that requires the back to be removed.
What - How - Ware ? Yes I looked online for the parts, no I was not successful in finding the parts online. Can you tell me ware you found the parts for this project?
