Saltar al contenido principal
Samsung Galaxy Tab 10.1 Rear Panel Replacement
Qué necesitas
  1. Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab 10.1 Rear Panel Replacement, Rear Panel: paso 1, imagen 2 de 2
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Rear Panel Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: paso 2, imagen 3 de 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Rear Panel Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab 10.1 Rear Panel Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
Conclusión
13 personas más completaron esta guía.
Davie Sy
Miembro Desde 09/30/13
1,421 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-5, Forte Fall 2013 Miembro de Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Miembros
17 Guías creadas
4 comentarios
Very interesting, but my note 10.1 does not have these two screws adjacent to the charge point as you describe. So mine is a bit different. There are no screws anywhere on the tablet. So how do I take the back off mine ??
James Tobin - Contestar
It currently won’t start and I have read about a fix that requires the back to be removed.
What - How - Ware ? Yes I looked online for the parts, no I was not successful in finding the parts online. Can you tell me ware you found the parts for this project?
Brian Elling - Contestar
i need the panel
Ay Bami - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 38,979
