Saltar al contenido principal
Samsung Galaxy Tab 10.1 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Tab 10.1 Motherboard Replacement, Rear Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Rear Panel: paso 1, imagen 2 de 2
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 2, imagen 3 de 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  4. Samsung Galaxy Tab 10.1 Motherboard Replacement, Battery: paso 4, imagen 1 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Battery: paso 4, imagen 2 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Battery: paso 4, imagen 3 de 3
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
  5. Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  6. Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement: paso 6, imagen 3 de 3
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
  7. Samsung Galaxy Tab 10.1 Motherboard Replacement, Volume and Power Button: paso 7, imagen 1 de 1
    • Hold down the motherboard with your finger and use a spudger to gently pry up the connection for the volume keys and power key.
  8. Samsung Galaxy Tab 10.1 Motherboard Replacement, Flash and Rear Camera Connection: paso 8, imagen 1 de 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Flash and Rear Camera Connection: paso 8, imagen 2 de 2
    • Using the flat end of a spudger, disconnect the black flash cable connector from the motherboard.
    • Disconnect the white rear-facing camera connector.
  9. Samsung Galaxy Tab 10.1 Motherboard Replacement, Front Camera, Micro SD card/headphone Connection: paso 9, imagen 1 de 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Front Camera, Micro SD card/headphone Connection: paso 9, imagen 2 de 2
    • Use the flat end of a spudger to disconnect the orange front-facing camera connector.
    • Disconnect the blue Micro SD card/headphone jack connector from its socket on the motherboard.
  10. Samsung Galaxy Tab 10.1 Motherboard Replacement, Speakers and Antenna Connection: paso 10, imagen 1 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Speakers and Antenna Connection: paso 10, imagen 2 de 3 Samsung Galaxy Tab 10.1 Motherboard Replacement, Speakers and Antenna Connection: paso 10, imagen 3 de 3
    • Using the flat end of a spudger, disconnect the orange speaker connectors for the left and right speakers.
    • Disconnect the gold antenna cable connector from its socket on the motherboard.
  11. Samsung Galaxy Tab 10.1 Motherboard Replacement, Motherboard Removal: paso 11, imagen 1 de 2 Samsung Galaxy Tab 10.1 Motherboard Replacement, Motherboard Removal: paso 11, imagen 2 de 2
    • Lifting from the bottom edge, gently remove the motherboard.
Conclusión
18 personas más completaron esta guía.
Davie Sy
Miembro Desde 09/30/13
1,421 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-5, Forte Fall 2013 Miembro de Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Miembros
17 Guías creadas
5 comentarios
Comment passe t'on de l'étape 6 à 7 ? (plastique gris qui fait le tour)
Sebastien Mlakar - Contestar
My 10.1 tablet switches on but the only thing showing on the screen is the “Samsung Galaxy 10.1” logo.
If the on/off button is held down for 20 seconds or so the screen goes blank for a few seconds then the logo reappears but nothing else happens. This logo only disappears when the battery is fully discharged.
After re-charging the battery the whole process is repeated
Any suggestions as to the problem
Jim
Jim Smith - Contestar
I'm having the same issue
PBRECHEISEN5567 -
have anyone found a solution?
Shaun Smith - Contestar
What if I don't have screws on the outside of tablet?
Stacy Moseley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 68
Todo El Tiempo: 46,538
