Saltar al contenido principal
Samsung Galaxy Tab A 10.1 S-Pen Speaker Replacement
Qué necesitas
  1. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: paso 1, imagen 1 de 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 3, imagen 3 de 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  5. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the ribbon cable from the socket.
  6. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the two 4mm Phillips #000 screws from the speakers.
  7. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 7, imagen 1 de 2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: paso 7, imagen 2 de 2
    • Use a plastic opening tool to pry the speakers out of the tablet
Conclusión
2 personas más completaron esta guía.
Guneet Bawa
Miembro Desde 04/12/18
688 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G5, Liner Spring 2018 Miembro de UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 370
