Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The mother board is the heart and soul of this device. Everything from the operation system to the camera and audio port runs through the motherboard. If either component is faulty then the whole mother board needs to be replaced. This guide will help show you how to replace the motherboard right in your own home.
Partes
No se especificaron partes.
  1. Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
  2. Once rear cover is off use small pastic spudger to lift battery out of the phone Once rear cover is off use small pastic spudger to lift battery out of the phone
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
  3. After following how to remove the battery, unscrew the five 1.2mm Phillips Screws  on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
  4. Once screws are removed turn the phone over and use the plastic opening tool and  unclip the connector holding the screen to the motherboard.
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
  5. Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
  6. Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps. Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
    • Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
Conclusión
3 personas más completaron esta guía.
Kevin Teque
Miembro Desde 10/03/16
291 Reputación
2 Guías creadas
Equipo
more information please....
me good - Contestar
What information are you looking for?
Kelsea Weber -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 2,844
