Introducción
For the Cricket Samsung Galaxy Sol, the camera needed is an OEM CRICKET SAMSUNG GALAXY SOL SM-J321AZ rear camera. Some of the reasons you would need to replace the front camera are water damage or a cracked lens.
Qué necesitas
Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
