Saltar al contenido principal
Samsung Galaxy Sol Headphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Sol Headphone Jack Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Headphone Jack Replacement, Headphone Jack: paso 3, imagen 1 de 1
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
  4. Samsung Galaxy Sol Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Turn the phone around and remove the screen using the plastic tool.
  5. Samsung Galaxy Sol Headphone Jack Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the headphone jack at the top of of the phone by carefully removing it with tweezers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 358
