Saltar al contenido principal
Samsung Galaxy Sol Front Camera Replacement
Qué necesitas
  1. Samsung Galaxy Sol Front Camera  Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Front Camera  Replacement: paso 2, imagen 1 de 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Front Camera  Replacement, Front Camera: paso 3, imagen 1 de 1
    • Remove all ten 0.4 mm screws with a Phillips #00 screw bit. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Front Camera  Replacement: paso 4, imagen 1 de 1
    • Remove the front camera at the top left of the phone be carefully removing it with tweezers.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 439
