Saltar al contenido principal
Introducción
Using these steps, you can replace the front camera on your Galaxy SIII Mini VE.
  1. Flip your phone so you are facing the back. Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing. Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Use your finger or an opening tool to pry the battery out of the phone. Use your finger or an opening tool to pry the battery out of the phone.
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  5. Using an opening tool, gently separate the plastic framing from the phone. Using an opening tool, gently separate the plastic framing from the phone.
    • Using an opening tool, gently separate the plastic framing from the phone.
  6. Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger. Next, use the spudger and tweezers to remove the speaker at the top of the phone. Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  7. Locate the front camera connection. Using the tweezers, lift the holding tab at the base of the ribbon wire. Again, using the tweezers, gently pull the front camera out and away from the phone.
    • Locate the front camera connection.
    • Using the tweezers, lift the holding tab at the base of the ribbon wire.
    • Again, using the tweezers, gently pull the front camera out and away from the phone.
Conclusión
2 personas más completaron esta guía.
Megan
Miembro Desde 23/10/14
1,152 Reputación
6 Guías creadas
Equipo
Michigan Tech, Team 1-8, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 5
Todo El Tiempo: 911
