Saltar al contenido principal
Samsung Galaxy SIII Mini VE Battery Replacement
Qué necesitas
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: paso 1, imagen 1 de 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: paso 1, imagen 2 de 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: paso 1, imagen 3 de 3
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: paso 2, imagen 1 de 2 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: paso 2, imagen 2 de 2
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: paso 3, imagen 1 de 2 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: paso 3, imagen 2 de 2
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
Conclusión
9 personas más completaron esta guía.
Megan
Miembro Desde 10/23/14
1,186 Reputación
6 Guías creadas
Equipo
Michigan Tech, Team 1-8, Lauer Fall 2014 Miembro de Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 3,358
