Introducción
This guide will show the steps necessary to remove and insert a new battery into the Samsung Galaxy SIII Mini VE.
Qué necesitas
Flip the phone over so you are viewing the back.
Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
Set the rear casing aside for future use.
Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
Place the old battery aside for now, or dispose of it properly.
Locate your new battery.
Correctly orient the new battery to be inserted.
Gently insert the new battery into the battery slot.
9 personas más completaron esta guía.
