Saltar al contenido principal
Samsung Galaxy SIII Mini Display Assembly Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 2 Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: paso 1, imagen 2 de 2
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 2, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 2, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 2, imagen 3 de 3
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
  3. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 3, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 3, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 3, imagen 3 de 3
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 4, imagen 1 de 1
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 5, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 5, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 5, imagen 3 de 3
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  6. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 6, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 6, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 6, imagen 3 de 3
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  7. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 7, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 7, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 7, imagen 3 de 3
    • Gently separate the menu buttons flex cable from the touchscreen.
  8. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 8, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 8, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 8, imagen 3 de 3
    • If the display is left on the frame, use the same techniques to remove it.
  9. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 9, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 9, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 9, imagen 3 de 3
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  10. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 10, imagen 1 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 10, imagen 2 de 3 Samsung Galaxy SIII Mini Display Assembly Replacement: paso 10, imagen 3 de 3
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  11. Samsung Galaxy SIII Mini Display Assembly Replacement: paso 11, imagen 1 de 1
    • That's all.
    • Did you do it successfully?
Conclusión
18 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,341 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,541 Guías creadas
2 comentarios
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - Contestar
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 17,505
