Saltar al contenido principal
Samsung Galaxy SIII Mini Camera Failed Troubleshooting
Qué necesitas
Resumen del Video
  1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: paso 1, imagen 1 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: paso 1, imagen 2 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: paso 1, imagen 3 de 3
    • Go to:
    • > Settings
    • > Application manager
    • > All
    • >Camera
    • Clear data and cache and check that the camera works. If no, go to the next step.
  2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: paso 2, imagen 1 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: paso 2, imagen 2 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: paso 2, imagen 3 de 3
    • Go to:
    • > Settings > Backup and reset
    • > Factory data reset
    • > Reset device > Erase everithing
    • !!! This will erase all your data !!!
    • For a Hard reset using hardware keys, follow this manual:
    • Samsung Galaxy - Wipe data/Factory reset
  3. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: paso 3, imagen 1 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: paso 3, imagen 2 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: paso 3, imagen 3 de 3
    • Open sammobile and make an registration.
    • Search the firmware for your model and find the variant, corresponding to your mobile phone.
    • You can see the variant from Settings > About the device, or from dialer app by entering *#1234#
    • In the download page you can find instructions and link to the Odin app.
  4. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: paso 4, imagen 1 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: paso 4, imagen 2 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: paso 4, imagen 3 de 3
    • Switch off the phone and remove the battery and any SIM and memory card.
    • Remove the Midframe.
    • Disconnect the Menu buttons and the SD card reader flex cables.
    • Lift the board slightly to the left side and be careful with the earpiece and the main camera - they are stuck to the Display frame.
  5. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: paso 5, imagen 1 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: paso 5, imagen 2 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: paso 5, imagen 3 de 3
    • Disconnect the LCD Display flex cable.
    • Open the camera flex cable connector and reconnect the camera.
  6. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: paso 6, imagen 1 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: paso 6, imagen 2 de 3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: paso 6, imagen 3 de 3
    • If the camera still does not work, the last step is camera replacement.
  7. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: paso 7, imagen 1 de 1
    • Did you do it successfully?
Conclusión
16 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
192,056 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,525 Guías creadas
3 comentarios
I did it! I did it! I did it!
I save time and money!
Thank you sooooo much!
Batis Kaf - Contestar
how did you do it?!
zohny.omar -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 9,596
