Saltar al contenido principal
Samsung Galaxy S8 Plus Display Assembly (With Frame) Replacement
Qué necesitas
Instrucciones de Vídeo
Conclusión
33 personas más completaron esta guía.
Jeff Suovanen
Miembro Desde 08/06/13
428,095 Reputación
259 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,816 Guías creadas
5 comentarios
something to note, not sure if the guy mentions in video (it’s german, I didn't actually watch it) :
If you try and test the new display before you reassembled the mid frame, you will get a temperature warning. reinstall all screws and mid frame then test, should be good.
also, this is the only method you should attempt this repair, as the official samsung screens will come like this, with frame. If not, its not original, don’t waste your time or money on sh!tty parts
Andrew - Contestar
Agreed! I love my OEM Samsung Service Box Display
Ethan Bain - Contestar
Best video I’ve seen of the S8 teardown. Agree with what Andrew said above, check the midframe to see all the extra small parts are there. To check everything works, you can turn on the phone with after connecting the display to the motherboard, and puting the internals back together (everything but gluing the front and back pieces). Be careful to put all the screws back in place- the motherboard needs a tight connection to components on the midframe (like the power button and audio speaker) to work. Good luck!
Michael M - Contestar
Can I buy the screen replacement
Christian lares - Contestar
How can i by samsung Galaxy 8+ screen?
Nguse Hayelom - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 25
Ultimos 30 días: 87
Todo El Tiempo: 31,127
