Introducción
Samsung Galaxy s7 If your home button is not working? Solution! How to fix any Samsung Galaxy Home Button Galaxy g930F!
Qué necesitas
Instrucciones de Vídeo
Casi Terminas!
Conclusión
2 personas más completaron esta guía.
5 comentarios
Hi,
Recently screen replaced with new homebutton - now fingerprint sensor is only giving error, any way to fix this?
Phone is rooted and has cust.firmware installed.
Try to fix :
factory defaults
reboots
cleared cache
Thanks for your reply!
Patrick Pieck - Contestar
Thanks for you info.
www.movilone.es
MovilOne - Contestar
hi finger scanner is not working but home button is work please suggest me
Shamim Akhtar - Contestar
its cause the fingerprint sensor is synced with your logic board, you would have to write a script for it to work… which in that case would make you the first one to do so
Eric Touzin -
I need to replace the board of charger port with the module antenne, so I need to disamble the screen and don't know a what temperature I have to put the blower to not damage the LCD screen.
Joe Morel - Contestar
