Saltar al contenido principal
Samsung Galaxy S7 Active Disassembly
Qué necesitas
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: paso 1, imagen 1 de 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: paso 2, imagen 1 de 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: paso 3, imagen 1 de 2 Samsung Galaxy S7 Active Disassembly: paso 3, imagen 2 de 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: paso 4, imagen 1 de 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team S18-G1, Livingston Spring 2018 Miembro de Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Miembros
15 Guías creadas
Un comentario
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 22
Todo El Tiempo: 4,340
