Introducción
Removing the rear glass panel from your Galaxy S6 destroys the adhesive holding it in place. Follow this guide to replace the adhesive tape on your Galaxy S6's rear glass. Most adhesive strips will come packaged as shown, although the film dimensions and color may vary.
Before beginning, we recommend you remove any residual adhesive from the glass panel using a lint-free cloth and solvent such as high concentration isopropyl alcohol (at least 90%).
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
Qué necesitas
141 personas más completaron esta guía.
8 comentarios
It would be handy to tell us a reliable place to obtain the adhesive from as iFixit doesn't appear to stock it
Will the adhesive for a galaxy s6 work on the back cover of an s6 edge?
It won't work. Size is different. One for S6 is larger
Jimmy -
Couldn't you just cut it to size? If it's just a pad of adhesive, you should be able to just cut it to the smaller backing size. I'd assume it's non conductive, but make sure it's not blocking anything important.
Ampera -
amazon has the S6 film
