Saltar al contenido principal
Samsung Galaxy S6 Midframe Assembly Replacement
Qué necesitas
  1. Samsung Galaxy S6 Midframe Assembly Replacement, SIM Card: paso 1, imagen 1 de 2 Samsung Galaxy S6 Midframe Assembly Replacement, SIM Card: paso 1, imagen 2 de 2
    • Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
    • Press to eject the SIM card tray.
    • Don't press too hard or you may damage the SIM card tray.
  2. Samsung Galaxy S6 Midframe Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the SIM card tray from the phone.
  3. Samsung Galaxy S6 Midframe Assembly Replacement, iOpener Heating: paso 3, imagen 1 de 2 Samsung Galaxy S6 Midframe Assembly Replacement, iOpener Heating: paso 3, imagen 2 de 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  4. Samsung Galaxy S6 Midframe Assembly Replacement: paso 4, imagen 1 de 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  5. Samsung Galaxy S6 Midframe Assembly Replacement: paso 5, imagen 1 de 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  6. Samsung Galaxy S6 Midframe Assembly Replacement, Alternate iOpener heating method: paso 6, imagen 1 de 2 Samsung Galaxy S6 Midframe Assembly Replacement, Alternate iOpener heating method: paso 6, imagen 2 de 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  7. Samsung Galaxy S6 Midframe Assembly Replacement, Rear Glass: paso 7, imagen 1 de 2 Samsung Galaxy S6 Midframe Assembly Replacement, Rear Glass: paso 7, imagen 2 de 2
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • Shift the iOpener to heat the remaining section of the panel for another two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  8. Samsung Galaxy S6 Midframe Assembly Replacement: paso 8, imagen 1 de 3 Samsung Galaxy S6 Midframe Assembly Replacement: paso 8, imagen 2 de 3 Samsung Galaxy S6 Midframe Assembly Replacement: paso 8, imagen 3 de 3
    • Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
    • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
    • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
  9. Samsung Galaxy S6 Midframe Assembly Replacement: paso 9, imagen 1 de 2 Samsung Galaxy S6 Midframe Assembly Replacement: paso 9, imagen 2 de 2
    • Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    • Re-heat the rear glass as needed to prevent the glue from cooling and hardening.
  10. Samsung Galaxy S6 Midframe Assembly Replacement: paso 10, imagen 1 de 3 Samsung Galaxy S6 Midframe Assembly Replacement: paso 10, imagen 2 de 3 Samsung Galaxy S6 Midframe Assembly Replacement: paso 10, imagen 3 de 3
    • Repeat the heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick under each edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S6 Midframe Assembly Replacement: paso 11, imagen 1 de 2 Samsung Galaxy S6 Midframe Assembly Replacement: paso 11, imagen 2 de 2
    • Use an opening pick to slice through any remaining adhesive.
    • Remove the rear glass.
  12. Samsung Galaxy S6 Midframe Assembly Replacement: paso 12, imagen 1 de 2 Samsung Galaxy S6 Midframe Assembly Replacement: paso 12, imagen 2 de 2
    • To install new rear glass:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
  13. Samsung Galaxy S6 Midframe Assembly Replacement, Midframe Assembly: paso 13, imagen 1 de 1
    • Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
  14. Samsung Galaxy S6 Midframe Assembly Replacement: paso 14, imagen 1 de 3 Samsung Galaxy S6 Midframe Assembly Replacement: paso 14, imagen 2 de 3 Samsung Galaxy S6 Midframe Assembly Replacement: paso 14, imagen 3 de 3
    • Before you perform this step, make sure you've ejected the SIM card tray.
    • Firmly grasp the edge of the midframe assembly.
    • Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
    • While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
    • Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
    • Be careful not to accidentally insert the opening pick between the glass and display.
    • To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
    • You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
  15. Samsung Galaxy S6 Midframe Assembly Replacement: paso 15, imagen 1 de 1
    • Lift the midframe assembly up to separate it from the rest of the phone.
Conclusión
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
17 personas más completaron esta guía.
Dante Mazzanti
Miembro Desde 07/13/15
36,174 Reputación
26 Guías creadas
6 comentarios
Step 18
Is it really that "simple" to separate the midframe from the front of the phone? In most videos (even the one on ifixit) a suction cup is used (after warming the front) with some prying tools.
So, does Step 18 really work?
It appears that the front is hold together by only 4 adhesives in the corners. Are this damaged during the front removal process? (is there a replacement kit?)
Just another question, I damaged the heart sensor plastic cover, is it possible to buy just that part or do I need to buy a complete midframe?
paulo - Contestar
Can this step be exactly with a simple push as stated? Other sources required focusing heat on the 4 corners and run through with a pick....?
Secondly, how can one avoid damaging the lamination under the glass while removing it or trying to get the first foothold with the pick. Most guides I have seen appear to skip this step.
ahmad - Contestar
I have seen one phone parts site (EtradeSupply) list all different variants of the mid housing (G920F, G920V, G920R etc). But another site (WitRigs) has just one, as if they aren't specific.
Does anyone know? Because i'm in Australia and can't find G920i variant.
Also, has anyone simply swapped over the antennas, and crimped them onto the new housing?
Joshua Rayner - Contestar
Ok Guys I am definitely !#^&@@ off right now.... but to the point.
Please Edit to this guide --> @Step 18:
First of all: Heat the for corners with your iOpener to lose the adhesive which sits in the corners.
Be very very gentle when you push down on the battery and try to put a little pressure onto or maybe into the headphone jack when you first encounter that the display gets lose, because the headphone-jack fits very well in the frame and holds on a little corner.
Only go around the whole display with a spudger when the adhesive is really warm to lose it when it doesn't come out as easy as you thought. Because otherwise you may face that the display to display-glass laminate gets damaged. That just happened to me at the upper display side... so to get a perfect new looking phone I have to replace that as well....EXPENSIVE :(
Hope this may help you guys.
but ... nevertheless ... thank you guys from IFixit for your continous effort to help people repairing there stuff - heads up :-)
jakob - Contestar
Hi Jakob, thanks for your input! When writing this guide we used a device that had been previously disassembled, so our experience may have been different from yours. Just to be clear: you have an issue with step 18 because the adhesive between the midframe and front assembly is very strong and simply pushing the battery is not adequate? Are there other steps that need to be adjusted?
And, as a general note, you can edit this guide yourself! When you hover your cursor over any particular step, an "Edit" button will appear. Alternatively, you can scroll to the top of the page and click the "Edit" tab up there.
Evan Noronha -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 25
Todo El Tiempo: 24,488
