Introducción
Over-charging, water damage, or quickly and repeatedly inserting and removing a USB device may lead to a damage on the USB board of the Samsung Galaxy S6 Active. Use this guide to replace the USB board in your Samsung Galaxy S6 Active.
Before beginning, make sure to completely power off your phone and disconnect it from any external power source.
Qué necesitas
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
Use a plastic opening tool to undo the connector and the two wires on the motherboard.
