Introducción
Use this guide to uninstall and replace the motherboard from your phone. After uninstalling the motherboard you will also be able to access the front camera, the power button, and the volume button.
Qué necesitas
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
3 personas más completaron esta guía.
