Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy S6 Active Front Camera Replacement
Qué necesitas
    1. Samsung Galaxy S6 Active Front Camera Replacement, SIM Card: paso 1, imagen 1 de 2 Samsung Galaxy S6 Active Front Camera Replacement, SIM Card: paso 1, imagen 2 de 2
      • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
      • Pry open the tray to get it out of the socket.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Galaxy S6 Active Front Camera Replacement: paso 2, imagen 1 de 1
      • Remove the SIM tray with SIM card from the phone.
      Pregunta a FixBot
      Agregar Comentario
    1. Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: paso 3, imagen 1 de 3 Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: paso 3, imagen 2 de 3 Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: paso 3, imagen 3 de 3
      • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
      • If using an iOpener, heat it in a microwave for thirty seconds.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Galaxy S6 Active Front Camera Replacement: paso 4, imagen 1 de 1
      • Attach a suction cup to the lower half of the screen.
      Pregunta a FixBot
      Agregar Comentario
    3. Samsung Galaxy S6 Active Front Camera Replacement: paso 5, imagen 1 de 2 Samsung Galaxy S6 Active Front Camera Replacement: paso 5, imagen 2 de 2
      • Using the suction cup, pull gently the lower half of the panel.
      • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
      Pregunta a FixBot
      Agregar Comentario
    4. Samsung Galaxy S6 Active Front Camera Replacement: paso 6, imagen 1 de 3 Samsung Galaxy S6 Active Front Camera Replacement: paso 6, imagen 2 de 3 Samsung Galaxy S6 Active Front Camera Replacement: paso 6, imagen 3 de 3
      • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
      • Slide the plastic opening tool around the screen, prying the display gently away from the body
      Pregunta a FixBot
      Agregar Comentario
    5. Samsung Galaxy S6 Active Front Camera Replacement: paso 7, imagen 1 de 1
      • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
      • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
      Pregunta a FixBot
      Agregar Comentario
    6. Samsung Galaxy S6 Active Front Camera Replacement: paso 8, imagen 1 de 3 Samsung Galaxy S6 Active Front Camera Replacement: paso 8, imagen 2 de 3 Samsung Galaxy S6 Active Front Camera Replacement: paso 8, imagen 3 de 3
      Herramienta utilizada en este paso:
      • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
      Pregunta a FixBot
      Agregar Comentario
    7. Samsung Galaxy S6 Active Front Camera Replacement: paso 9, imagen 1 de 1
      • Undo the screen connection with a plastic tool.
      Pregunta a FixBot
      Agregar Comentario
    8. Samsung Galaxy S6 Active Front Camera Replacement: paso 10, imagen 1 de 1
      • Remove the display assembly (LCD and Digitizer).
      Pregunta a FixBot
      Agregar Comentario
    1. Samsung Galaxy S6 Active Front Camera Replacement, Battery: paso 11, imagen 1 de 2 Samsung Galaxy S6 Active Front Camera Replacement, Battery: paso 11, imagen 2 de 2
      • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Galaxy S6 Active Front Camera Replacement: paso 12, imagen 1 de 1
      • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
      • You will hear the clips start undoing themselves.
      Pregunta a FixBot
      Agregar Comentario
    3. Samsung Galaxy S6 Active Front Camera Replacement: paso 13, imagen 1 de 2 Samsung Galaxy S6 Active Front Camera Replacement: paso 13, imagen 2 de 2
      • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
      • The battery will be on the back side of this frame.
      Pregunta a FixBot
      Agregar Comentario
    4. Samsung Galaxy S6 Active Front Camera Replacement: paso 14, imagen 1 de 1
      • Insert a plastic opening tool on the side of the frame and pull out the battery.
      Pregunta a FixBot
      Agregar Comentario
    5. Samsung Galaxy S6 Active Front Camera Replacement: paso 15, imagen 1 de 2 Samsung Galaxy S6 Active Front Camera Replacement: paso 15, imagen 2 de 2
      • Remove the battery from the frame.
      Pregunta a FixBot
      Agregar Comentario
    1. Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: paso 16, imagen 1 de 3 Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: paso 16, imagen 2 de 3 Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: paso 16, imagen 3 de 3
      • Use a plastic tool to undo all the connections in the motherboard.
      • There are three connections that have to be removed.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Galaxy S6 Active Front Camera Replacement: paso 17, imagen 1 de 2 Samsung Galaxy S6 Active Front Camera Replacement: paso 17, imagen 2 de 2
      • Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
      Pregunta a FixBot
      Agregar Comentario
    3. Samsung Galaxy S6 Active Front Camera Replacement: paso 18, imagen 1 de 1
      • Remove the motherboard from the rear case.
      Pregunta a FixBot
      Agregar Comentario
    1. Samsung Galaxy S6 Active Front Camera Replacement, Front Camera: paso 19, imagen 1 de 2 Samsung Galaxy S6 Active Front Camera Replacement, Front Camera: paso 19, imagen 2 de 2
      • The front camera will be attached to the back of the motherboard.
      • Turn the motherboard around and use a plastic tool to undo the connection of the front camera.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Galaxy S6 Active Front Camera Replacement: paso 20, imagen 1 de 1
      • Use the tweezers to remove the front camera from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Lucia Valbuena
Miembro Desde 02/15/17
2,538 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 1-5, Sullivan Spring 2017 Miembro de USF Tampa, Team 1-5, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G5
Miembros de 3
96 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 49
Todo El Tiempo: 1,120
