Introducción
Use this guide to replace the microSD card.
Qué necesitas
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot.
Remove the microSD card from the phone.
23 personas más completaron esta guía.
Un comentario
My S5 won't read or format a high speed SD card. Any suggestions?
