Saltar al contenido principal
Introducción
This guide will show someone how to safely remove the motherboard from the device. It is rather easy to do after the front screen and the plate underneath it are removed.
Note: In order to replace the motherboard, you will have to remove the screen. Because this is a waterproof phone the screen will most likely break during its removal. Be prepared to have to replace the screen as well.
  1. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top.
    • Remove the back casing of the phone using the notch located at the top.
  2. Lift up the battery using a plastic spudger or fingernail. Damaging the battery may result in physical injury and/or damage to the phone. Damaging the battery may result in physical injury and/or damage to the phone.
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Turn on the heat gun. Make sure you don’t touch the metallic tip. You will burn yourself.
    • Turn on the heat gun.
    • Make sure you don’t touch the metallic tip. You will burn yourself.
    • Hold the heat gun roughly 6 inches away from the screen of the phone and slowly run the heat around the edge of the screen.
    • Keep at least 6 inches of distance from the screen. Keep moving the heat around to avoid warping the phone screen or internal parts.
  4. Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible. Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  5. The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger. In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  6. Remove the screws around the plate Remove the screws around the plate Remove the screws around the plate
    • Remove the screws around the plate
  7. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity.
    • Push the plate out by applying pressure to the battery cavity.
  8. Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily. Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily. Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
  9. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity.
  10. Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard. Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard.
    • Detach the pink and white wires by pulling gently on the metallic caps that connect them to the motherboard.
  11. Remove the black connector above the wires by pulling straight up with tweezers. Remove the black connector above the wires by pulling straight up with tweezers.
    • Remove the black connector above the wires by pulling straight up with tweezers.
  12. Pull the motherboard out.  It should lift easily out of the phone. Pull the motherboard out.  It should lift easily out of the phone. Pull the motherboard out.  It should lift easily out of the phone.
    • Pull the motherboard out. It should lift easily out of the phone.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-6, Leahy Spring 2016 Miembro de USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,275
