Introducción
This guide will show someone how to safely remove the motherboard from the device. It is rather easy to do after the front screen and the plate underneath it are removed.
Note: In order to replace the motherboard, you will have to remove the screen. Because this is a waterproof phone the screen will most likely break during its removal. Be prepared to have to replace the screen as well.
Qué necesitas
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
Una persona más ha completado esta guía.
