Saltar al contenido principal
Samsung Galaxy S5 Sport Front Facing Camera Replacement
Qué necesitas
  1. Samsung Galaxy S5 Sport Front Facing Camera Replacement, Battery: paso 1, imagen 1 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Battery: paso 1, imagen 2 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 2, imagen 1 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 2, imagen 2 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Front Facing Camera Replacement, Screen: paso 3, imagen 1 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Screen: paso 3, imagen 2 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Screen: paso 3, imagen 3 de 3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 4, imagen 1 de 2 Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 4, imagen 2 de 2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Front Facing Camera Replacement, Front-Facing Camera: paso 5, imagen 1 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Front-Facing Camera: paso 5, imagen 2 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement, Front-Facing Camera: paso 5, imagen 3 de 3
    • Remove the screws around the plate
  6. Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 6, imagen 1 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 6, imagen 2 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 6, imagen 3 de 3
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 7, imagen 1 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 7, imagen 2 de 3 Samsung Galaxy S5 Sport Front Facing Camera Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-6, Leahy Spring 2016 Miembro de USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 626
