Introducción
Use this guide to remove and replace the battery in a Samsung Galaxy S5 mini.
If your battery is swollen, take appropriate precautions.
Qué necesitas
Insert a fingernail or a plastic opening tool into the slot located above the power button.
Gently pull the panel off the back of the phone.
Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
Gently pry the battery away from the phone.
7 personas más completaron esta guía.
2 comentarios
that was so so hard!
But battery not charging properly
