Introducción
Ir al paso 1 ↓To replace the 16 megapixel rear-camera, follow the steps to remove all previous components required. Take full precaution when operating tools such as heat guns, as they can cause potential health hazards.
Qué necesitas
Herramientas
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
7 personas más completaron esta guía.
6Guía Comentarios
Where did you purchase the replacement camera/lens?
Same here. I only need the lens cover.
On ebay sales
What if I'm just replacing the glass and not the entire camera?
Did you get an answer already? Or did you find a solution in the mean while? My cameraglass is also broken...
