Saltar al contenido principal
Samsung Galaxy S4 Mini Speaker Replacement
Qué necesitas
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Speaker Replacement: paso 3, imagen 1 de 1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: paso 4, imagen 1 de 2 Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: paso 4, imagen 2 de 2
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: paso 5, imagen 1 de 1
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: paso 6, imagen 1 de 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: paso 6, imagen 2 de 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: paso 6, imagen 3 de 3
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: paso 7, imagen 1 de 2 Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: paso 7, imagen 2 de 2
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: paso 8, imagen 1 de 1
    • Insert the new loud speaker
Conclusión
31 personas más completaron esta guía.
Luis Ojeda
Miembro Desde 09/23/14
989 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 9-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
5 Miembros
11 Guías creadas
3 comentarios
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 21
Todo El Tiempo: 13,769
