Saltar al contenido principal
Samsung Galaxy S4 MicroSD Card Replacement
Qué necesitas
  1. Samsung Galaxy S4 MicroSD Card Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy S4 MicroSD Card Replacement, Rear Case: paso 1, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 MicroSD Card Replacement: paso 2, imagen 1 de 3 Samsung Galaxy S4 MicroSD Card Replacement: paso 2, imagen 2 de 3 Samsung Galaxy S4 MicroSD Card Replacement: paso 2, imagen 3 de 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: paso 3, imagen 1 de 3 Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: paso 3, imagen 2 de 3 Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: paso 3, imagen 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
Conclusión
28 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,762 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
Un comentario
If you use Micro SD card the you must know to How to Recover Memory Card
we are not going to use any app/softwares we only use CMD and 5 exclusive methods
http://www.gogorapid.com/how-to-recover-...
Ramal jayaratna - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 18
Ultimos 30 días: 37
Todo El Tiempo: 87,535
