Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Use this guide to replace a worn-out or defective battery on your Samsung Galaxy S4 Active.
If your battery is swollen, take appropriate precautions.
Partes
No se especificaron partes.
  1. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
Conclusión
12 personas más completaron esta guía.
Josh Forester
Miembro Desde 28/11/10
2,379 Reputación
10 Guías creadas
Having the worst trouble ever with SAMSUNG devices. I thought "active" was meaning what it is sappost to mean...... NOT. WILL. NEVER OWNA SAMSUNG DEVICE AGAIN!
anotherfinefinish2 - Contestar
Device was a gift. Never had seen this level of disassembly before on this device. After breaking several fingernails and getting nowhere trying to discover how to get into this thing, resorted to jewelers screwdrivers and everything went very smoothly. Otter case was greatest challenge but after it eventually separated, opening the phone case was a snap and these directions were perfect and not a problem. Easy, once you understood where to separate the pieces and the jewelers screwdrivers worked very well without the special $1.95 plastic tool mentioned. I was worried about breaking or chipping the plastic but it seems to be very pliable and nothing chipped or broke with these jeweler's tools (mostly used for my glasses).
jotaito - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 6,942
