Saltar al contenido principal
Samsung Galaxy S21 Screen Protector Replacement
Qué necesitas
  1. Samsung Galaxy S21 Screen Protector Replacement, Screen Protector: paso 1, imagen 1 de 2 Samsung Galaxy S21 Screen Protector Replacement, Screen Protector: paso 1, imagen 2 de 2
    • Remove the phone case and place phone on a flat, clean surface with the screen facing upward.
  2. Samsung Galaxy S21 Screen Protector Replacement: paso 2, imagen 1 de 1
    • Remove the damaged screen protector carefully.
    • Usually this can be done with fingernails, but a plastic credit card or ID can make removal easier.
  3. Samsung Galaxy S21 Screen Protector Replacement: paso 3, imagen 1 de 2 Samsung Galaxy S21 Screen Protector Replacement: paso 3, imagen 2 de 2
    • Clean the phone screen off with an alcohol wipe to remove any fingerprints and dust from the screen.
  4. Samsung Galaxy S21 Screen Protector Replacement: paso 4, imagen 1 de 1
    • Wipe and dry the phone screen with a microfiber cloth.
  5. Samsung Galaxy S21 Screen Protector Replacement: paso 5, imagen 1 de 2 Samsung Galaxy S21 Screen Protector Replacement: paso 5, imagen 2 de 2
    • Use stickers or tape to remove any dust particles that may have settled on the phone screen.
    • Have the new screen protector easily accessible during this step.
  6. Samsung Galaxy S21 Screen Protector Replacement: paso 6, imagen 1 de 2 Samsung Galaxy S21 Screen Protector Replacement: paso 6, imagen 2 de 2
    • Peel back the protective layer on the screen protector, and carefully line up the camera cutout with the front-facing camera, laying the top of the screen protector onto the phone screen.
  7. Samsung Galaxy S21 Screen Protector Replacement: paso 7, imagen 1 de 1
    • Let the rest of the screen protector fall onto the screen, ensuring that the screen protector is square with the phone screen.
  8. Samsung Galaxy S21 Screen Protector Replacement: paso 8, imagen 1 de 1
    • Press the screen protector into the screen with your fingers, starting in the middle of the screen and working outwards.
  9. Samsung Galaxy S21 Screen Protector Replacement: paso 9, imagen 1 de 1
    • Work out any bubbles with the scraper/card by applying firm pressure into the screen protector and slowly sliding towards the nearest edge.
Conclusión
Now you have a brand-new screen protector! Enjoy the fresh look.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 38
Todo El Tiempo: 427
