Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Galaxy SII Screen Replacement Tutorial
Partes
No se especificaron partes.
  1. Galaxy SII Screen Replacement Tutorial
    • Galaxy SII Screen Replacement Tutorial
  2. Remove battery door and battery
    • Remove battery door and battery
  3. Remove all screws on the back of the plastic frame
    • Remove all screws on the back of the plastic frame
  4. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  5. Use a plastic tool to separate the rear frame from the front
    • Use a plastic tool to separate the rear frame from the front
  6. Now disconnect all connectors on the motherboard, making sure the front camera and buzzer. This is attached with the double-sided adhesive.  As a precaution, remove the audio ear speaker. In all this we will always help with a plastic instrument and a spudger. Remove with a thin tool "iSesamo" the volume rocker and power switch side, these are fixed with adhesive tape
    • Now disconnect all connectors on the motherboard, making sure the front camera and buzzer. This is attached with the double-sided adhesive. As a precaution, remove the audio ear speaker. In all this we will always help with a plastic instrument and a spudger.
    • Remove with a thin tool "iSesamo" the volume rocker and power switch side, these are fixed with adhesive tape
  7. Now we can remove the logic board Now we can remove the logic board
    • Now we can remove the logic board
  8. Remove the USB connector by unscrewing the two screws.  Reinstall the new display starting from this step to number one on the procedure. Remove the USB connector by unscrewing the two screws.  Reinstall the new display starting from this step to number one on the procedure.
    • Remove the USB connector by unscrewing the two screws. Reinstall the new display starting from this step to number one on the procedure.
Conclusión
59 personas más completaron esta guía.
AndreaBaglione
Miembro Desde 06/11/09
3,834 Reputación
3 Guías creadas
Hello AndreaBaglione,
We are iphone lcd dealer in China, and looking for original Iphone lcd, especially for 5G, both new and used accepted, quantity will be over 1000 and even more. Would you let me know whether you are doing this business or any channel that you can recommend? Thank you in advance. lihanshan@163.com
Best regards
Fiona
fiona - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 8,447
